Suddenly acting sluggish - Page 2 - MustangForums.com
Old 12-06-2006, 09:07 PM
mattdel
mattdel's Avatar
Default RE: Suddenly acting sluggish
you can check the ignition stuff yourself with some basic tools, pull the plugs out, check them, open the dist. cap and look at the electrode tips, make sure they're not burnt.
the injector pulse will have to be checked at a shop, requires some knowledge of EFI systems and special tools.
mattdel is offline
Old 12-06-2006, 09:08 PM
mattdel
mattdel's Avatar
also a fuel pressure gauge can be screwed into the fuel rail for the injectors, should be around 39psi running.
mattdel is offline
Old 12-06-2006, 09:10 PM
shibby_cbs
thanks
shibby_cbs is offline
Old 12-06-2006, 09:15 PM
84redfox
It does kind of feel like a clogged cat maybe, because I bought the car with one and had to replace it. But I replaced it about 2k miles ago, what could make it go bad that soon?
84redfox is offline
Old 12-06-2006, 09:18 PM
FiveLiterRiceEater
a bad cat could be because of air/fuel mixtures being rich. raw fuel will kill a cat. it sounds more like you need to adjust your carb. what carb are you running?
FiveLiterRiceEater is offline
Old 12-06-2006, 09:22 PM
84redfox
just the holley 600cfm. I know it has to do with my carb, but I just don't know what.
84redfox is offline
Old 12-06-2006, 09:25 PM
FiveLiterRiceEater
you'll have to take it somewhere to have the carb adjusted cause its hard if you dunno what you're doing, and easy to screw up. it could be as simple as having the carb adjusted. but you could also have low fuel pressure as well. are you still using the little inline filter in the carb?
svfetter
10-05-2015 11:39 AM
wraith777
09-28-2015 10:49 AM
StalkerGT
09-25-2015 02:41 PM
96stang3.8
09-10-2015 06:42 AM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Suddenly acting sluggish
Featured Sponsors
