Swap an 88 5.0 into a 95 HELP
Old 12-06-2006, 11:25 PM
gr84u
gr84u's Avatar
Default Swap an 88 5.0 into a 95 HELP
Alright so my buddy and I are doing an engine swap and we have an 88 to put in his 95. What exactly needs to be swapped. I've heard that the water pump spins differenty on the 95. That is as much as I know besides the intake as well...
gr84u is offline
Old 12-07-2006, 01:02 AM
dimebag
dimebag's Avatar
Default RE: Swap an 88 5.0 into a 95 HELP
im not sure? but why ya doin the swap?
dimebag is offline
Old 12-07-2006, 02:05 AM
AdderMk2
Banned
AdderMk2's Avatar
block swaps directly in... so do the heads
waterpump spins in the same direction.... whoever told you otherwise if a retard
AdderMk2 is offline
Old 12-07-2006, 02:39 AM
gr84u
gr84u's Avatar
He destroyed the engine, running 147 for miles at a time. We don't want to swap the heads, it would be unecessary wouldn't it since they are both E7's..
gr84u is offline
Old 12-07-2006, 09:35 AM
AdderMk2
Banned
AdderMk2's Avatar
like i said... the heads and block are the same... so strip the 88 motor of everything but the block and heads, and swap everything ense from the 95 block over... the only difference between the water pump is the way it interfaces with the belt. but why use an old pump in the first place... put a new one on it.... this is also the PERFECT time to do an H/C/I
AdderMk2 is offline
Old 12-07-2006, 12:26 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
and dump that crappy 'puter in the '95
2 kwik is offline
Bokeo
10-10-2015 08:28 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: Swap an 88 5.0 into a 95 HELP
