Best intake
What does everyone think the best intake for a 5.0 is?
RE: Best intake
Victor jr, or super victor (dependson your heads).
-P. |
RE: Best intake
www.tmossporting.com
depends on set-up really, read thru that guys site A well ported GT-40 will have more "average flow" than most intakes, due to low end velocity but the Holley seems to have the best top-end flow. |
RE: Best intake
:Devery intake is the best when set to it's rpm range and flow of other compents
RE: Best intake
voted GT40 beacuse price and availibility, can be easily ported to meet the needs of your setup, and i totally agree with r.barn on the fact this poll isn't reflective cause each is meant for a specific need.
RE: Best intake
ok with this setup what is best
255lph fuel pump 24 lb injectors 76mm calibrated mass air 70mm throtle body (upper and lower intake)??? 3:73 gears Chip and dyno tune 1.7 RR electric fan smog delete P/s deleteBBk CAI |
RE: Best intake
oh and its an auto tranny and had long tubes and a prochamber
RE: Best intake
For your set up I'd reccomend the Trick Flow Street Heat. The track heat is aimed more for a higher revving motor with heads and a cam.
RE: Best intake
well you still have not said where you want the power at they are all goood for there specific rpm range you did not put the trickflow street heat has good bottom.. what pm range are you going to be driving at most the time..
Completly off topic what rpm are you at, when your cruising about 70 in 5th with those 3.90's 92hatchlx |
RE: Best intake
ORIGINAL: LX 90 ok with this setup what is best 255lph fuel pump 24 lb injectors 76mm calibrated mass air 70mm throtle body (upper and lower intake)??? 3:73 gears Chip and dyno tune 1.7 RR electric fan smog delete P/s deleteBBk CAI |
