Pulling engine
RE: Pulling engine
Why do you need a tech article. Start disconnecting the wiring, etc. unbolt your motor mounts and than start to pull it. You will realize where you are catching at and than work from there. If you never pulled and engine before thats the easiest way.
RE: Pulling engine
It's really not hard, but get some egg crates or something where you can label all the bolts and parts you pull....assembly will be much easier. I learned that one the hard way. DOH!!!
Pull it w/ the tranny on it if you want to save a little extra time.
09-01-2015 08:16 PM
