What RWHP and 1/4 miles times ?
RE: What RWHP and 1/4 miles times ?
whats wrong with the c&l... ??? it used the stock meter is why i liked it... which also made it cheaper.... and the filer looks just like a K&N... are they bad or something.... ???
C&L's are known for their lack of tunability... every local shop around here will refuse to tune your car if you are running a C&L...
the idea is to get RID of the stock maf sensor because it doesnt have very good resolution... and just adjusting the size of the hole the air can flow through isnt a good way to adjust how a maf works...
get a 80mm Pro-M and be done with it.
and adder i would like to note that my friend has a 95 gt and for whatever reason he loves his stock heads (granted they are ported pretty good) but still and he has reworkde the whole motor new block and internals and crank he went with a b303 cam and a edelbrock intake i dont kno which one and a cai 75 mm t/b and bigger maf sensor again not sure which ones and he has put down 320 hp to the wheel so i dont doubt them that much
ORIGINAL: AdderMk2
I like your video adder.
everyone knows that STOCK e7 heads suck major donkey *****.... addint a cam will do NOTHING if you still have stock heads...I still say he will be lucky to get past 240rwhp
ih8chevy those ar worked heads... like i plan on gettin my gt-40 ported and polished.... they will flow much better.... if they werent worked i would be amazed but worked heads are like ****ty aftermarket heads... dont take that offensive like i said im doin it to....
adder were can i get a good deal on a 80 mm pro maf..... and if i plan on gettin a kb 2.2 s/c so would it be worth gettin a new intake now??? wont i need new stuff then newayz??
I think he said he was using an '83 GT. That car wieghts 100's less than any of the '94-95's did. 100# a tenth remember.
Flat tappet motor, too bad about the gearing, 4.10's would really wake it up, in fact, the rest of the E7 engine not a bad idea.
I'd carb it.........
ORIGINAL: CrazyCobraSpeed
ORIGINAL: tinman
Typically anyone that has to ask "how fast is my car in the 1/4?" has obviously never BEEN to the track... so im gonna assume his first few runs will be in the 15's
How much do you think an 83GT weighs?? I can tell you that My car only tips the scales at 3230lbs
ORIGINAL: hrd2bslw
How much RWHP would this car put down. and how fast could it go in the 1/4 mile.
83 Mustang GT, Stock Bottom End 302, Stock E7 Heads, Edelbrock Torker ll Cam (214/224 Duration @ 50 & 472/496 Lift)
Edelbrock Torker ll Intake Manifold, Motorcraft 650 CFM Carb, 1 5/8" Longtubes, 2 1/2" Exhaust w/Dynomax Mufflers
SROD 4-Spd Tranny, 2.73 gears, 225/50/15 Goodyear F1 Tires.
ORIGINAL: ZachW04Stang
With that torker manifold your gonna need some more gear then that. I'm suprised your not complaining it bucks under 2500rpm. That manifold won't allow any low end and doesn't make power till 3000rpm.
ORIGINAL: hrd2bslw
sorry togo off topic on this but i will make it really quick, ZachW04. what collor int is in your 86? if it's grey then i am very interested in buying your center console armrest off you.. i need it to complete my int. i have all the original int... but with a **** red center armrest.lol..
and back on topic. carb cars are known for making more power then a fuel injected car because there is less restriction in the intake system so i could see why maybe he might make cloe to 260hp.
Displ8cement
Texas Regional Chapter
08-13-2015 12:37 PM
