$100 Junkyard Longblock??????
RE: $100 Junkyard Longblock??????
ORIGINAL: yamablaster024
what is the difference between short block and long block? What did stock come with?
A long block is all the above plus: heads, intake and exhaust manifolds, ignition system, induction system, and engine harness.
ORIGINAL: MACDRIVE
A short block is just the block, cam, lifters, crank, rods, pistons, oil pump, oil pan, all the bearings, and water pump.
A short block is a block, crank, rods, and pistons
A long block is block crank, rods, pistons, cam shaft, timing chain, timing cover, and heads
ORIGINAL: ZachW04Stang
My understanding has always been different but I may be wrong.
ORIGINAL: MACDRIVE
You could very well be right. Besides, I forgot about the gear set anyway.
The local 'pick-a-part' down here in Tucson is $130 for any complete V-8 engine...
Sounds like some peep's are getting raped.
Shop more carefully.
BTW, thhe local 'pick-a-part' type place place here had probably something like 15-20 complete 5.0 Fords last time I was the about thanksgiving but some were out of trucks, Crown Vic's stc......
jwog666
12-27-2021 08:09 PM
