Fox Body ECU in SN95
RE: Fox Body ECU in SN95
ORIGINAL: ISwearItsStock
I was told Pro-M and Pro-Form make a PIH that makes it so you dont have to switch any pins, just connect the two. Anyone know of this?
Do some searches on the following sites
Stangnet
Corral
SBFTech
You should find some resources there. I know I have seen links to the harness you mentioned on Stangnet.
Still, I don't see any reason for making the change.
Good Luck, and let us know what you decide!!!
jason
Another problem you will run into is the cobra(if your car is a cobra) is they have 24# injectors and the fox ecu will be setup for 19's, so you'll have to buy a new MAF sensor to run the 24s in it. I also read on stangnet that many of your gauges on the dash will not be funcional if you did this swap.
one of my buddies around town did it and he suggested it to me. i heard that sn95 will not run very well with a cam if you don't have a tune or the fox ecu. i have been thinking about doing it cause i want to get a cam. i believe he said he got a kit from summit and it tells you everything you need to do, he says it wasn't to hard to do at all
