SEA FOAM? CANT FIND IN SEARCH
RE: SEA FOAM? CANT FIND IN SEARCH
Treats 3 Critical Areas: Gas Tank, Fuel Systems, and Crankcase
Cleans fuel injectors
Cleans carburetor jets
Cleans carbon
Stabilizes fuels
Upper cylinder lube
Removes moisture in fuel
De-icer
Frees sticky lifters
Frees sticky rings
Removes moisture in oil
Cleans P.C.V. systems
Cleans catalytic converter odors
Oxygen sensor safe
When Used Thru Injection or Carburetor
Cleans carbon build up
Cleans intake valves and pistons
Gives smoother idle
Cures hesitations and pings
Restores power and pickup
When Added to Crankcase (Oil)
Frees sticky lifters and rings
Increases R.P.M.'s vacuum and compression
Cleans dirty parts
Removes moisture
Cleans PCV valve systems
One pint treats 10 quarts of oil (avg. 1 1/2 ounce per quart).
When Added to Fuel Tank
Cleans fuel injectors and carburetor jets
Cleans carbon as you drive
Lubricates upper cylinders
De-ices and removes moisture
Diesel full conditioner and anti gel
Stabilizes fuel
One pint treats 8-25 gallons of fuel (average 1 ounce per gallon).
Cleans carbon
Stabilizes fuels
Upper cylinder lube
De-icer
Frees sticky rings
Oxygen sensor safe
Gives smoother idle
Cleans dirty parts
Removes moisture
Stabilizes fuel
