what is need for a efi to carb in a 89 stang?
RE: what is need for a efi to carb in a 89 stang?
Its a lot more parts then people think, you need a pickup for your tank, fuel pump, fuel regulator (if pump puts out more then 6 psi), fuel line, intake manifold, carberator, distributer, ignition box, and a new coil. If you put a mechanical pump on you need a new timing cover as well. Wiring everything up is cake.
zach you can do it with less than that holley red fuel pump intake manifold carband a stand alone dizzy my buddy has one on his f150 really really nice dizzy im gunna be getting one that way i can get ride of the damn wiring harness
I ran an 85 distributer w/ a msd 6al ignition box. There were many wires at all. Are you talking about a points distributer? I hope not, theres a reason no one uses them anymore.
i would have to say a 3 only cause of the dizzy with the couple wires you have to hook up other than that you have to make sure you have fitting in the back of the intake for the brake booster hose to plug into and if your getting a vacuum advanced dizzy you need a spot to plug that line in as well
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
