the cam choice for the 86 stang
as u all know now the tfs heads wil fit hte block and clear he ptv and the cam that tf suggested is their stage 1 cam which is a very good cam
hope this helps u flat top guys
RE: the cam choice for the 86 stang
did you tell them your car was speed density? i am pretty sure the tfs 1 cam will not work with speed density very well at all.... also.. that would be really close on the ptv clearence issue.. i wouldnt be surprised if they actually did hit and you would still need to notch the pistons... i'm not sure if they are just suggesting it cause it is theres and they want to make money off you or if it would actually work.. i just am very skeptical about that.
Every engine is different..you WILL need to clay the heads before installing that cam and though I'm not sure you have flat tops, I am fairly certain the TFS cam will not work with flats...there will be contact. Should also note as stated above...the SD set up can be quite disagreable with non SD friendly cams and TFS1 cam is not one I'd put on the friendly list.
this is true and i m emailing them back telling them that i have a sd setup and that i dont kno if it willl work and if it will clear, but they had said that the cam will clear and it should work so we shall c in a little while i guess
my man i think u need to learn somethin about ediquate i never said i was ordering first u should read second i said this is just info for someone who wants to stay with teh 86 motor i never said i m getitin it did i
u dont read thats a problem or u dont comprehend i thik u should stop talkin ****
Actually I'm typing....and I should note your spelling/sentence structure leaves comprehension a difficult task for me so forgive me for not understanding your babble as well as you would have liked. What you've done is state as FACT something that infact is not fact...and might end up costing a member who puts faith in your post....money.
mungodrums
Suspension
09-24-2015 10:12 PM
