C4 or C6??? PLEASE HELP!!
RE: SERIOUS TRANY Q
ORIGINAL: forzdinduxshin
you know, I should really just shut my pie hole and read a little bit more, they sell the f**kin "multi fit block plate" and it will bolt right up.
NOW THAT I SHOT MYSELF IN THE FOOT, YOU MAY ALL LAUGH!![:'(]
RE: SERIOUS TRANY Q
if you get a c-4 make sure you get a matching block plate and correct flywheel weight as there
are a few differnt bellhousing sizes, just make sure you have the later model auto flywheel so it will fit inside bellhousing , c-6's don't have removeable bellhousings, tailhousing yes, if you go with that one just make sure to get the small block style as even the 300 6 has the same bolt
pattern all the way up to 351 w 's , not 351m's
RE: SERIOUS TRANY Q
I answered my own question that I've been asking all night, the make a multi fit plate that will bolt the C4 to a 289-351w. so if I go new I'll have to buy the bell housing, find one used then no. question I was looking at bell housings and you can buy one for a C4 with 157 tooth fly wheel but there's two options it says standard, then there's another one that says (not SFI) what's that mean??
RE: SERIOUS TRANY Q
Pricey = Yes
Overated = Yes
Maybe not too much on C4's but the prices for their built AOD's is absolutly insane.....
RE: SERIOUS TRANY Q
I'm probably not going new, see my wonderful grandpa in all his greatness has a C4 sitting on the floor of his shop, do a nice little rebuild, fork the money for a new converter and bam!!!! C4 in my ride!!!
