Stand Alone Ignition....
RE: Stand Alone Ignition....
Unless you're worried about an electromagnetic pulse weapon frying all the electronic circuits in the United States, you should go with a Mallory Unilite. Those duel point distributors need constant adjustment. But you might enjoy regapping your points all the time, I don't know.
haha, so i should look into a mallory UNILITE then? Still looking for the correct coil.
So This distributer...Unilite and One of them Voltage regulators, and I guess I can use the stock coil with it. And Thats all I need im guessing ignition wise to make it work with this setup? I really appreciate this help by tha way...
ORIGINAL: subhumantat
with my swap i went with a points dizzy and carb intake to make things alot easier with less wiring, other than that it is pretty much a stand alone runs on it's own with no need for a computer
ORIGINAL: VigCS
Points are usually much more complicated and less reliable than an electronic ignitor/pickup...
