Am I reading this corretly on how to plug smog pump pipe holes in heads? - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 5.0L (1979-1995) Mustang
Reload this Page >
Old 12-13-2006, 07:57 AM
Evil_F
Default Am I reading this corretly on how to plug smog pump pipe holes in heads?
:::How to plug the heads' smog pump holes:::
Go to your local hardware store and buy 5/8" bolts. I bought 2 that were 2" long then cut them
down to be about 3/4"
Once you have them cut you will want to file a groove into the threading and make it like a tap.
use the bolt to fill in the hole for a much cleaner and less of a "hey look... i have spark plugs
stuck in the back of my cylinder heads!!!!" look... make sure you slowly work the bolt back and
forth until it bottoms all the way down... then back it out, apply some red rtv silicone or thread
sealer, and thread it back in.
I think it was Adder that posted this. Are the holes threaded? Because the pipes are held in there with plates bolted to head. I was was wanting to get rid of the pipe. Anybody???
Evil_F is offline
Old 12-13-2006, 11:56 AM
g2_5point0
Default RE: Am I reading this corretly on how to plug smog pump pipe holes in heads?
i filed the edges until i was able to insert it and thread it in. it's been there for months now and it's still plugged up pretty good
g2_5point0 is offline
DrunknRuckus
08-23-2015 11:05 AM
Figure8allday
08-22-2015 12:11 PM
MusBBad95
08-17-2015 10:39 PM
Soldier GT
08-12-2015 04:46 PM
djbigskrilla
08-11-2015 01:59 PM
Featured Sponsors
