351 Q&A
RE: 351 Q&A
I dont think we are talking about a Cleveland engine
if we are, its a whole different story................
ORIGINAL: rwh129
is your 351c a 2v or 4v
1970 & 71 had a higher HP rating
2v 240 HP
4v 285 HP
4v 330 HP (Boss 351)
1972-1974
2v 163 HP
4v 248 HP
4v 266 HP (HO)
http://www.theclassicmustang.com/1972_engines.htm
2v 240 HP
4v 285 HP
1972-1974
2v 163 HP
4v 248 HP
4v 266 HP (HO)
RE: 351 Q&A
ORIGINAL: Hurricanedt77
The cleveland being the big block correct? I heard some stories about those things, Huge power.. Right?
yes they can make good power, just not as many aftermarket parts for them is only downside.
RE: 351 Q&A
ORIGINAL: blazinyellowbeast
SO there is no diffence in the blocks besides the cams? I have a chance to get one before my buddy junks it, I just want to know what I am getting into before I do.
The 69 block was a shorter deck height, but it wasn't by much.
Most rotating assy. kits will work with both, but it is worth knowing what block you are using before getting the rot. assy.
The blocks did change through 69-74 as rbarn mentioned.
I would post the writeup on my site, but I can't access feewebs from work.
The major concern comes if you want to run off the shelf Hyd. roller 302 cam profiles.
You can convert a non roller 351w block to accept stock 302 hyd roller lifters, if you use a reduced base circle cam.
The reduced base circle cams are not highly acclaimed by Pro engine builders though, as they throw off the geometry between the Lobe and the lifter.
The best way to run a standard base circle cam on a non roller 351w is to utililize the 'link bar' style lifters. These are offered by numerous cam companies, but they are expensive.
jason
RE: 351 Q&A
ORIGINAL: r.barn
It's still a small block, just different than the Windsor
RE: 351 Q&A
not really, they were all small blocks and dont tell me i am wrong cause i kno this stuff i kno more about those motors than the 5.0, which is not sayin too much, but i kno for a fact that the cleveland was a small block and the 351/400m were small/ meduim blocks none were big blocks fords only big blocks for the record were 352, 390, 427, 428, 429,460, 406
if you think i m wrong go on the net and search
ORIGINAL: black_pearl_gt
nope they are big blocks the 289-351w were smalls and the 351c-460 were bigs and the m blocks were bigs too
ORIGINAL: r.barn
Mustangs of Illinois
08-22-2015 10:00 PM
