ok, get a damn 8.8 put 3.73s in it... depending on power might wanna go w. 31splines, or just 28 mosers... so then if your getting a new rear, wtf was the point of the question?
if you read what you wrote it says should i switch to something better like a 3.73... should u switch means should you switch or stay the same.... there for i assume you meant to eithe use the 7.5 or upgrate the 7.5 gear... then you threw in that you were gettting a 8.8... so that makes it sound like your asking if you should use the 3.45 or upgrade... see how it doesnt make sense...
so if your question is 3.55 or 3.73. then my question is what kinda hp/tq numbers do you expect?
