351w heads on 5.0??
351w heads on 5.0??
just wondering hoe much of a difference there is in hp/torque or any suggestions cause i dont have too much money and someone gave me a set of 351 heads for $$$0 And need some info or help???!!
RE: 351w heads on 5.0??
I heard of some people doing that swap but I dont know actuall numbers I do know they flow better so if its not going to cost you anything to put them on do it but you should have them maxed out just for good measure
plz i had a set of factory70 351w heads.. with194/16 valves back cut for flow and still flowed around 198 on intake side///my edelbrock rpms stock form flowed224/178 if i remember right on a flow bench.. the ford 351w heads that were 69/70 had like a 184/154 valves..and didnt flow no 198 from factory..and ported they ran about 220s or so...with bigger valves..edelbrocks i have 224 and when was ported i flow 276 intake side..but for ford 351w heads in those years they are good..buy the timeya pay to have done up good///a set of windsor jrs/srs are just as cheap...
