Are Convertible doors same as t-top?
Old 12-15-2006, 01:36 AM
erikpd
erikpd's Avatar
Default Are Convertible doors same as t-top?
Hi!
I'm new to these forums with the purchase of an '87 LX 5.0 T-Top. The car I bought is pretty beat cosmetically. The doors are rusting at the bottom. I am wondering if convertible doors are the same as t-top doors? I read a random mustang parts ad on eBay where the seller stated that covertible doors wouldn't work on a t-top car. Just need to know if this is true before I invest in convertible doors. I did do some searching but didn't find anything. Thanks!
Erik
erikpd is offline
Old 12-15-2006, 01:39 AM
84 Turbo stang
84 Turbo stang's Avatar
Default RE: Are Convertible doors same as t-top?
ive done it. it works. I had an 88 lx t-top that had a bad door. Conv worked fine. until my brother totalled it
84 Turbo stang is offline
Old 12-15-2006, 01:40 AM
mattdel
mattdel's Avatar
LX t-top? thought they were only gt's
mattdel is offline
Old 12-15-2006, 02:00 AM
84 Turbo stang
they might have been installed. I dont know anything about the car and that was 5 years ago. We should look that up
Old 12-15-2006, 02:09 AM
r.barn
r.barn's Avatar
more likely someone took the GT molding off and made it an LX at some time
never heard of an LX t-top.
r.barn is offline
Old 12-15-2006, 04:02 AM
hsean
hsean's Avatar
i have an 88 t-top gt and have the same problem and i plan on swapping out the windows over to rust free doors keep your windows i have been told that they are not the same. i have to sets of t-top windows just in case .i suggest you do the same find an t-top donor car and hold on to the windows and t-tops.
hsean is offline
Old 12-15-2006, 08:55 AM
goathead75
goathead75's Avatar
They did make LX t-tops, but the GT's are way more common. There are also notch t-tops as well. I just saw one of those a few weeks ago. Never knew that.
goathead75 is offline
Old 12-15-2006, 10:07 AM
wildsurfer92
wildsurfer92's Avatar
not sure about the doors themselves, but the vert windows are a bit smaller than the t-top windows, so the windows wont fit...and i assume the doors wont work because of that reason
wildsurfer92 is offline
Old 12-15-2006, 09:55 PM
bobbyward
bobbyward's Avatar
same doors different glass, the conv glass i think is shaped different at the rear near the 1/4 glass, in fact hard top door can be cut and turned into conv or t-top doors too !
they do make lx t-top cars as i have one that was a 84 lx with a 6cyl coupe
think that all the doors will interchange from 83-93 with no problems just use the correct glass and trim for your application
bobbyward is offline
Old 12-15-2006, 10:52 PM
84 Turbo stang
IVE DONE IT! it works.
lincolnshibuya
07-05-2020 03:05 AM
jerrytubes
10-23-2015 12:11 PM
b8checker
10-08-2015 12:55 PM
guitarman376
09-30-2015 05:54 PM
b8checker
09-30-2015 07:11 AM
Quick Reply: Are Convertible doors same as t-top?
