H/C/I swap
H/C/I swap
Around the first of the year im doing a H/C/I swap and i want to know if anyone has any sugestions to the parts im getting??
trick flow track heat upper and lower
Ford E cam
1.94/1.60 Stainless Undercut Valves 190cc Intake Runners 60cc Combustion Chambers
these heads http://www.tristatecylinderhead.com/...duct_info.php?
any sugestions
Ford E cam
any sugestions
RE: H/C/I swap
ORIGINAL: LX 90
i would like to know if that setup looks like it will match up nicley. Also i was planning on doing 24# injectors and mass air along with a bigger fuel pump and a 70mm throtle body.
Personally, I'm not a fan of the alphabet cams, but that's just personal preference. Before I give out my opinions on the setup, just curious what made you decide to get that matchup? (price, availability, already had some parts, etc)
RE: H/C/I swap
Do you have any future plans (forced induction?) If so you may wanna just toss in bigger injectors now if you're going to need them in the future anyway. Don't forget headers too. You probably don't want to bolt stock garbage up to that setup.
Well the heads look like crap and only maybe a step above E6 heads found on the 86 mustangs. Another concern is the advertised GT40P's having 60cc chambers.
RE: H/C/I swap
ok try this link http://www.tristatecylinderhead.com/...roducts_id=106
and who makes custom cams. Also does that look like a good setup with a custom cam??? what kind of power woul i produce. And fuinally have your ever heard of tri state cylinder head??
