Hypereutectic Piston Questions
RE: Hypereutectic Piston Questions
Is the GT-40 crate motor considered a stock block? So should I spend the money to forge it before I put the supercharger on? and how much would fully forged internals run including shop costs? Thanks guys.
yes it's a stock block....no don't forge it just keep it at or under 450whp and you will be fine. i know more than a few people that have been running 400+whp on stock bottom's for a few years. i know two that have had 500+whp on a stock bottom for almost 2 yrs...but many more that didn't last with that power very long. the tune is very important!! again keep it under 450whp and you're fine. also...no need to get the afr's if you're going to supercharge it...the gt40's will get you to 450whp
then if you decide you want more power build a new engine
so the hyper pistons should be good at that hp range to. And the S/C I was gonna put on was the Vortech with Aftercooler and that says it only ups it 155 hp. So with the AFR's shouldn't that put me around 400-450? http://www.vortechsuperchargers.com/...ustang_ho.html
It's the Supercharging System with V-2 SQ & Aftercooler for 1986-1993 5.0 Mustang H.O., it's for the 5.0 HO so will it fit my motor?
ORIGINAL: Dropdagloves20
http://superchargersonline.com/
You have to email them to get a price quote. For a Vortech V1 they were several hundred dollars cheaper than summit.
I noticed you're in Albuquerque, why not go Hellion?
