MY TRANNY@!!!@!@!@!
MY TRANNY@!!!@!@!@!
Hey everyone... I just bought a 95 Mustang GT auto. I am having tranny problems it has 75000 miles on it. When i have it in drive and pull up to a stop sign and then take off at about 3000 it shifts at like 2000 or so and it boggs down the engine and it bounces a little from not having enugh rpms.. does every one understang this problem?
I tried to explain it.. it seems like it shifts at the wrong rpms but i dont know why.
RE: MY TRANNY@!!!@!@!@!
Couple of things to check. If (as I suspect) it is an AODE/4R70W, check TPS or VSS. If it is just an AOD, check on the throttle body linkage and make sure that the bushing for the TV cable hasn't deteriorated and fallen out.
ORIGINAL: Trannyman
also 95stang5.0, have you ever changed the fluid and filter in it yet? 75,000 miles is about 25,000 too late to be doing it if it hasn't been done, ain't that right Trannyman???
Umm i dont know if the kid has changed it or not.. i havent, that is what i am going to do first to see if that helps.. is there a special kind of tranny fluid i need? and i thank all of you for your help.
Just make sure to get the Ford type tranny fluid, can't remember the name off the top of my head but Ford uses a different fluid from the rest of the others. Think it is called Type F to distinguish it from the other kind. I'm sure the auto parts store can make sure you get the right kind and don't forget to change the filter while you're at it too.
treesloth
09-28-2015 07:03 AM
jaiidutch
09-14-2015 10:29 AM
