need help with 70mm MAF
RE: need help with 70mm MAF
ORIGINAL: primetime5.0
the cobra meter is calibrated for 24# injectors, so it wont work
The Cobra does not have a 24# calibrated MAF.... its got a TUNED ECM for 24# injectors... the MAF will work in a 19# car
ORIGINAL: Mowin8603
C&L..
ORIGINAL: tom50
What is a good MAf to get??
ORIGINAL: AdderMk2
Wrong wrong wrong.... god, im sick of correcting people on this.
the sensor has nothing to do with it, the sample tubes are different sizes from 19#'s to 24#'s
Adder's info is correct.
Adder is correct,
Ford cailbrates injectors to the computer.
There is a seperate calibration for the MAF.
HOWEVER...
The 70mm MAF MUST be used with the sensor from a 94-95 Mustang.
This is the ONLY way to run a 70mm MAF on a Fox computer.
Good Luck
HOWEVER...
Good Luck
jwog666
12-27-2021 08:09 PM
stangin1996gt
09-21-2015 11:01 AM
