Distributor
Distributor
As some of ya'll may know, I am going through distributor hell. I ordered a new MSD (luckily they are holding the order until I am sure), posted it here and PRO50 and a few others said it was the wrong one. I found this one which looks identical to the Motorcraft which is in there now.
Here it is along with the coil. Is it the right one and can I run it in conjunction with a MSD 6AL box? THANKS SO MUCH, Mitch....
http://www.atlanticspeed.com/product...idproduct=2838
http://www.atlanticspeed.com/product...idproduct=2797
RE: Distributor
Assuming you are still running EFI heres the part numbers you need:
Distributor: MSD-8456
Coil: MSD-8227
Coil to Box wire kit: MSD-8874
You don't need the wire kit, but it can make things simpler.
Coil: MSD-8227
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
