289 Hi-Po Heads
Old 12-17-2006, 07:00 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Default 289 Hi-Po Heads
My brother had our stang out last night and one of his friends said it looked like the car had 289 Hi-Po heads on it? Is there anyway to tell without taking the valve covers off? The heads are blue and the car has a **** load of torque.
Boss_Hotrod is offline
Old 12-17-2006, 07:07 PM
HACKGT350
HACKGT350's Avatar
Default RE: 289 Hi-Po Heads
what year mustang is this on?
HACKGT350 is offline
Old 12-17-2006, 07:08 PM
ZachW04Stang
ZachW04Stang's Avatar
Only way to really know is to take off the intake and use a mirror to see the date code on the bottom of the head.
ZachW04Stang is offline
Old 12-17-2006, 07:25 PM
Boss_Hotrod
Its on a 93 5.0. Only code I could see on them was a little number 23 on the driver side side in the front lower corner. If you are looking from the drivers side its upside down.
Old 12-17-2006, 09:20 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
hipo heads are identical to standard 289 heads with the exception of the screw in studs for the rockers instead of the standards pressed in
rmodel65 is offline
Old 12-17-2006, 09:28 PM
ZachW04Stang
ORIGINAL: rmodel65
How did they get 271hp out of a K code then with hipo heads and 210 out of a A code (I think thats a 4bbl) car without the heads.
Old 12-17-2006, 09:40 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
the acode was 225hp it was the cam change and the exhaust manifold the hipo turns more rpm to make those numbers
rmodel65 is offline
Old 12-17-2006, 09:47 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
https://mustangforums.com/m_766107/tm.htm
rmodel65 is offline
Old 12-17-2006, 11:01 PM
HACKGT350
HACKGT350's Avatar
i know the standard 289 has a 2bbl carb and the hi-po has a 4bbl carb and nicer exhaust my brother has a 65 289 hi-po
Old 12-17-2006, 11:41 PM
frdmstng1986GT
frdmstng1986GT's Avatar
rmodel65 is right. the hipo's used a solid flat tappet camshaft with better intake and exhaust manifolds with better exhaust. i am pretty sure they used a bigger carb too.
and the standard 289's had a 2v, but they also had the standard motor with a 4v. the had the c code(200hp 2v), a code(225hp 4v) and the k code( 271hp 4v) and also the shelby k code in the gt-350r( 306hp 4v.)
frdmstng1986GT is offline
Quick Reply: 289 Hi-Po Heads
