guess mods don't make your car faster..
RE: guess mods don't make your car faster..
no practice needed, it's an auto.. i hooked everytime, except one of them... best reaction time was.025 and a 2.2 60 ft.. car shifts slow from 2nd to third.. but i still was thinkin 14.7 could of and should of been hit
try timing it,adv it,,whats the timing at..did ya match ya springs on head to match cam.. on that cam peak torq is 3300 i think sotry shiftin a lil above that...what intake and the rpm rang of the intake...peak hp is 5100 on that b303 cam...reving it wa y past that is a waste..adv ya cam more,timing more,what was the comp on the cylinders...try better tires more traction//practice more with new set up..have it dynoed to find out what peak hp,and torq ya really have on ya motor..then u will know 4 sure where to shift..
Your car may be running worse with your new mods. A performance cam does no good for a stock engine. Not to mention those 24# injectors are drowning your engine with fuel. R Barn is running 24s on his 350rwhp 351W.
yea... i say run it a few more times... maybe just had a bad night? how was the car hookin? somethin doesnt sound right... i think you shoulda ran faster then what you did when you were stock(maybe, if any just a little), and w. all the mods listed yes you should have been in the 14s... hell the 3.73s shoulda gave you 14s... i think theres either a prob w. the car, or maybe the driver mod is a little rusty(no offence)???
First of all, valve springs is a HUGE MUST even with high mileage and the stock cam, especially with an aftermarket cam! You didn't list your trap speed of any of your runs (the only way besides a dyno to tell if you've added any real power). You're probably not going to get much better times with out a different torque converter either. Why didn't you just leave the 19 lb injectors in it? Why is your timing only at 10 degrees? I'm sure that you've heard it a million times but that sn-95 'puter doesn't like modifications, especially cams. I'd really re-think what you've done to your car, get it tuned right (bump timing and put stiffer valve springs in it) and give the 'ol 5.0 a second chance.
lol so ya have a new cam and old springs,,,hmmmmmmm redneckkkkkkkk lol..tired old springs dont open and close valves right on a perf cam..lose of power rightthere...timing needs more then 10 on a perf cam usually...try adv it a cpl degrees at a time...even if olssprings can handle the new lift..there olllllllllddddddddddddddddd..worn weak...new 1s are needed...
