what to get with $700
RE: what to get with $700
valve bodies take as long to install long as it takes you to unbolt your h/x pipe and valve body pan. its pretty much a drop out, place in, deal. i think your thinking of shift-kits that deal with the whole drilling and such to your current valve body. i'd just check out summitracing.com. if you want an easy and speedy do it yourself install, then go with the premade valve bodies. if you want to do it yourself or can remove the valvebody and take it to a shop to get it worked on, then buy the shift kit... it may save you a few bucks. having a shop drop the exhaust, then the pan and blah blah...theyll charge you just as much, if not more, than a premade valve body.
ORIGINAL: ih8chevy
well b4 someone else says it go to a junk yard and get teh gt40p's for about 90-100 then port them out, valve job, and mill em down to 59cc for 690 and that will give u a great performance upgrade
2003 4.75l
14
08-29-2015 02:58 AM
2003 4.75l
08-18-2015 10:35 PM
