electrial ?
ok i searched this but couldnt find a answer. Ok i had to disconnect some wires and when i put it back and tried to start the car, nothing the dash icons wouldnt come on nothing, only thing the seams to work is the horn and the dash lights that light up the ac and speedometer. if it is a ground which ground could it be, i took every ground off sanded it and put it back. i need this car fixed. thanx
RE: electrial ?
What exactly did you take apart? Some of the wire in the connectors can come loose and pull out. I had the problem when I took my dash apart last year. Make sure all connectors have all wire prongs plugged together.
RE: electrial ?
+1 What wires did you remove?
RE: electrial ?
everything from the shocks foward. [/align]
RE: electrial ?
bump
