AOD to T-5 Conversion
Looking for a little information! I'm sure it's been answered at some point but I have a 91 Lx 5.0 and am wanting to do a AOD to T-5 conversion but want to do it right, i've seen tons where the neutral saftey doesnt work, back up lights don't work etc. so if anyone knows a parts list I'd greatly appreciate it or where I could find one.
Thanks,
Brad
Thanks,
Brad
RE: AOD to T-5 Conversion
You'll need, a T-5 5 spd with bellhousing and clutch fork, a flywheel, starter, a shifter handle and boot, clutch/brake pedal assembly, a clutch cable, a clutch kit (pressure plate, clutch disc, pilot bearing and a throw out bearing). You might even need an ECU, but Im not positive on that. I think you only need to change the ECU if your car has an AOD-E (electronic).
And while youre at it, might as well replace the trans mount with an energy suspension component.
-P.
-P.
The Tech Articles cover this and much more.
https://mustangforums.com/m_2141191/tm.htm
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
11-10-2015 11:39 AM
