My set up, advice and help appreciated!!!
RE: My set up, advice and help appreciated!!!
ORIGINAL: live4motocross11
also how do i know if my stock motor has e7's so i can get the 100 bucks back from the core charge?
ALL v8 mustangs from 87-95 with the exception of Cobra's... have E7 heads!
hahahahaha that was great
but i think ur times would be mid 13's all day but nothing lower, dont expect 12's unless u got a lot suspension work to go with ur motor work
ORIGINAL: AdderMk2
your times will depend on how good you can drive. And if you drive like you paint... youll still be in the 15's
why the hell are u still goin wit e7's even thumperized i would still rather have a nice set of gt-40's at ur local junk yard or aluminum
i dont kno why people think they can make great hp with our stock heads
also i think the e7's come with nice upgraded stiff springs
where u located
well thats why im asking for advice, and i dont know if there r many 1996 explorers around here
and thanks for the paint comment........
compression test
since it dont look like ur milling em down u will still have similar compression somethin around 9:1 give or take a couple but u should def check ur local junk yard b/c thm gt 40s are a direct bolt on and tehy will give u a big advantage over the e7s jmo
lower eastern wisconsin
how would i find out what compression the ratio that i will have with that rebuild kit and the thumper e7's?
