Cooling system is acting wierd...need help ASAP!
#21
RE: Cooling system is acting wierd...need help ASAP!
You have some mad paint skills hack, LOL. I kinda understand, but I don't understand why I'd have an air bubble anywhere in the system. I never took the bottom hose off...but I'll trust you! Maybe I had a bubble in the system from when I did my water pump and it's not affecting my car until now.
I did take the top hose off (obviously) to do the thermostat, don't think that'd do anything. I'll burp it tomorrow and see how it goes.
#24
Sounds like you either have an air pocket or you have a very small leak. Does your heat go away when you come to a complete stop? I would try jacking the front of the car up and letting it run. Make sure you have the radiator cap off. Also when you burp the system make sure you have the heat on and at full blast that way you make sure coolant is working the air out of the heater core.
#25
ORIGINAL: VigCS
I know I do have a coolant leak but it's not a fast one. How exactly do I burp it?
As far as the temp flucts, you might not be holding pressure due to that leak you have, or you might need a new radiator cap.
#26
Hey, I am having the EXACT same problem with mine. Ive added coolant too, but my heat will kick off even driving and will start to overheat at any speed. I have been downshifting and running about 3,000 rpm and it seems to help. So what about this fellas? Does that help? What could it be? I put a stop leak in tonight and but idk if it worked or not.
#27
Stop leak is the worst thing you could have done, it will more than likely clog up the radiator. I would suggest doing what is being said in this thread on your car as well.
#28
ORIGINAL: stupidaso06
#30
ORIGINAL: tmajikman
