how to adjust a/f ratio
Old 12-21-2006, 07:48 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: how to adjust a/f ratio
ORIGINAL: 94gtcoupe
if he isn't burning all the fuel in it wouldn't make the timing slightly higher(1 or 2) hwlp to burn all the fuel??? and yea lowering the fuel pressure would help but it's kinda hard to do with out a adjustable fuel regulator isn't it?
not if you have a vaccum tool like I do... hehehe. you just slide the hose on the vac nipple and draw off some of the pressure.
AdderMk2 is offline
Old 12-21-2006, 07:50 PM
94gtcoupe
94gtcoupe's Avatar
good call adder i forgot about the little vacum lines
94gtcoupe is offline
Old 12-22-2006, 12:39 AM
dimebag
dimebag's Avatar
yea i just wanna lean it out a little to pass emissions, then put it back to normal. runs fine, timing is stock, all that good shyt. but its failing by such a little bit if i lean it out a little i think i can get it to pass. yea shes failed 4 times now, i have a new egr comming in the mail(thanks to r.barn, thanks again man). originally it failed nox and the unburnt fuel thing(cant remember name of it), and now i got the nox to pass(tried that "guarenteed to pass" shyt, n it helped, but didnt pass, guess i get my money back now, lol). ii wouldnt even say its running rich, theres no signs of it at all, just wanna try to lower it down a little for emissions testing, then back to normal.
dimebag is offline
Old 12-22-2006, 12:48 AM
dillon1340
dillon1340's Avatar
holy crap i'm glad i don't have to deal with that. good ole south carolina. not even inspections...
dillon1340 is offline
Old 12-22-2006, 12:51 AM
dimebag
dimebag's Avatar
this shyt has me contemplating sellin the damn thing, and buyin another one... its that frusturating... on autotrader right now...
dimebag is offline
Old 12-22-2006, 01:24 AM
dimebag
dimebag's Avatar
so n e quick easy fix or am i ****ed?
dimebag is offline
Old 12-22-2006, 01:34 AM
vt89gtvert
vt89gtvert's Avatar
I don't know for a fact that it would work, but try unblolting the exhaust just a little, mabye a 1/4 inch gap. If you do it to much then the machine might read a leak (Don't know what machine they are using). It lets some air in with the exhaust and generaly helps lower all the numbers.
vt89gtvert is offline
Old 12-22-2006, 02:24 AM
highway21
highway21's Avatar
high nox = high combustion temps above 2500 dg f check timing(to far advanced will cause high nox),egr, lean A/F mixture will cause high nox, and check catalytic converter.
high hc = lean miss fire. check ignition system, plugs, plug wires, timing(put at stock or 2 degrees lower than stock), internal compresion, vacuum leaks,air injection system.
high co = running rich/incomplete combustion. check carb, injectors, dirty filter, air injection system(air pump)
if push comes to shove just replace you cats and you shoud be fine!!!!!! i hope this helps you it would suck for you to sell you car over bar(bureau of automotive repair). I got this from bar smog check inspection manual. one more class and i get my smog license.
highway21 is offline
Old 12-22-2006, 02:31 AM
highway21
highway21's Avatar
new cats and retard timing 2 degrees from stock. you should pass with flying colors.
Old 12-22-2006, 02:33 AM
dimebag
dimebag's Avatar
really trying to avoid buying new cats... next weekend im installing an off road h-pipe, lol.
dimebag is offline
Quick Reply: how to adjust a/f ratio
