please help
RE: please help
yup, you eliminated the battery issue when you tried jump starting it, you were using the other vehicles battery to start your car, has your starter been acting up lately? like turning over hard, rrhhhrrhhrhrhhrhr? I'd replace the starter solenoid for $15 and see what happens. What voltage is your battery reading, should be 13-14, preferebly tested w/ load tester.
RE: please help
I couldnt jump my car one day, all it did was click, and I replaced the battery and it fired right up. I had a bad cell. If you can borrow a good battery and it wont start, then replace the solenoid. Sorry 7UP, but that is what happened to me.
RE: please help
Yea, I hear ya, hard to diagnose a truely dead battery without the load tester, it has enough amps to activate the solenoid but not enough to crank the starter... most likely, trying another battery direct would be a good start as well.
