About heads?
About heads?
If you bought a used car and your not sure wut kind of heads are on it.. Is there anywhere you can find out what kind ( by not taking the engine apart lol )by looking up there from under the car? Is there a part number or anything written on it visible to see?
RE: About heads?
The difference between cast iron and aluminum heads is very obvious. Your best bet is to look at the end of one of the heads...they should be the same, so whichever one you can see more clearly.
E7's (stock)=IIRC they say E7TE on the end...if not, it does say it on top of the head (under the valve cover)
GT40=3 vertical bars on the end
GT40P=4 vertical bars on the end
Aluminum heads=usually say Edelbrock, Trickflow, etc. on the end of the head.
RE: About heads?
well look on the front below the valve cover, there could be many different types itf it says tf or afr then you got those types of heads or like he said e ribs on front than its a gt40 head
RE: About heads?
ORIGINAL: gspfunk
Edit: Check between the recessed area in the middle spark plug gap.
