supercharger ?
supercharger ?
how much horses will a supercharger at 7 / 8 psi give me on a stock 5.0 with just and intake and exhuast can i chage the psi level and how and would other mods done to my car make the supercharger faster thanks for all your help guys you make it easy for me a novie mustang enthusiast i will be checking the form tommrow morning
RE: supercharger ?
At 8 pounds, you'll gain 80 - 88 HP on your mostly stock setup. To increase the PSI, you can get a smaller pulley. As far as other mods, swaping out the heads will get you some good gains. As will the intake / TB, but not quite as much. Heads will be the bottleneck right now.
RE: supercharger ?
KB(kennebell) advertises 100 WHP gains on a stock 5.0... and yes you can change boost levels, smaller pully= more boost bigger pully = less boost... after a supercharger and intercooler will give you abour 30-50 hp depending on the core... heads would greatly increase power (most restrictive component onthe motor)
