pulley question
RE: pulley question
ORIGINAL: PRO50SC
That is correct
ORIGINAL: rmodel65
he saying not to underdrive the alt so it will put out nice
RE: pulley question
^ ok.. all of your exsesories will still run off the same belt. its just when you get underdrive pulleys, they are smaller pulleys, and if you put the underdrive pulley on the alt then it would be as efficent, so pro was saying to not put the underdrive pulley on the alt so that you wouldnt run low volts.. like i am right now because i have underdrive pulleys. but yes id say upgrade to at least the 3g 130 amp unit. thats what i plan on doing. this is where i plan to get my 3g unit, http://www.pa-performance.com/displa...20+Max&rP=its the whole kit with everything you need to convert your 2g unit to the 3g unit.
RE: pulley question
ORIGINAL: Mowin8603
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
