idle and cam tech question
I installed x303 cam last week and now Im having troubles. First off I have checked all my vacume lines and set my timing and the fuel pressure. That said the car falls flat on its face when I come to a stop, even though it will idle decent in the drive. I have never had a larger than stock cam so I guess Im asking the following. Should the timing be raised when using a larger cam? Its at 14 now.
Maybe I should go over valves again?
Should I set my idle higher? Its around 900
Sorry this is so chopped up. Thanks to any who can help.
RE: idle and cam tech question
on tuesday I'm going to Clinton,IL to get my car tuned.do you know where that is. Anderson Ford Motorsport is there. where are you located. I am 30 miles east of St Louis. There is also turboconnections in Edwardsville.
I have bought parts from Anderson Ford but I believe they are around four hours away. I would hate to pull my car that far, but I have heard great things about the tuner at Anderson. I think his name is Mike.
