Typical headlight flickering question on using.....
RE: Typical headlight flickering question on using.....
in the dash where u turn them on theres 2 tabs that hold it in place plush the tabs on the left hand side of the switch and pull it out then remove the plug on the rear
My 93 went thru a few of those switches and they were a pain to remove, broke the tabs on one of them. The grey connector in back was melted so bad the wires backed themselves out.
No more foglights problem solved. Besides, the mounting plates for them weigh a ton and the long brace they connect to isnt exactly light either. Front ends heavy enough as it is.
treesloth
09-28-2015 07:03 AM
