Typical headlight flickering question on using.....
does the foglights cause the headlights to flicker ? its only done it once and i plan on trying to drive my car tomorrow night....if i do,if i leave the foglights off will the headlights act normal or will they still flicker ?
Jamie
Jamie
RE: Typical headlight flickering question on using.....
guess i should be more clear..if they actually flick off and on then you have a connection or ground problem..maybe at the switch. If they dim and get brighter randomly then its likely the alternator.
That's a typical fox problem, the fog light circuits need to be fixed.....check this article on the problem.
yeah its a nice place.....also i've only drove it a couple of times at night,1 of the times is when i got the car coming home, one of the foglights was out so i didnt turn just one on....came home 300 miles just fine....i replaced both foglight bulbs and used all the lights for the 1st time a couple of nights ago and they was flickering....i have those APC projector lights and spliced the small foglights by the headlight in with my parking lights with a inline fuse in both of them....sorry for the long read but i tried to be as clear as possible....let me know what you guys think...OHHH...the small foglights by the headlight wasnt flickering...only the headlights themselves
