HELP.....PLEASE, 5.0 question
My mustang started knocking and im going to pull the motor(302). My dad has a motor he would give me but Im unsure if it would work. Its a rebuilt 302 out of a 1960'smodel car. If I switched my lower and upper intake (if it would even bolt up)......would it work? Is this 1960's model motor interchangeable with my 1992 motor?
RE: HELP.....PLEASE, 5.0 question
alos, dont forget topick up a fuel pump block off plate cause the 60's motor used the mechanical pump on the block. also, that 60's motor is a hydraulic flat tappet motor while the one from your 92 is a hydraulic roller cammed motor. also,i think youneed a new distributor too.
ORIGINAL: frdmstng1986GT
starcle starcle little twink... who the hell you are you think...
Im not under the affluence of incohol, like some thinkle peep i am
The drunker I stay here, the longer I get
