help, cant get above 5,000 rpm
i have a 1992 5.0 bored 050 over mahle pistons, h-beam rods, trickflow intake2500-6500 rpm, comp cam1000-4700 rpm, but when the rpms get to 5,000 the motor starts to pop,spuder, ping, and it wont go any higher rpms, the msd box has a 6,000 chip, motor rebuilt 3000 miles ago w/new heads (stock) please help me
[sm=feedback.gif]
[sm=feedback.gif]
RE: help, cant get above 5,000 rpm
thats exactly what i was thinkin, dont matter if ur ignition box can rev that high if ur cam cant do it then it wont go
ORIGINAL: aode06
your cam stops making power at 4.700 rpm, is this valve float? or have you suddenly experienced this?
You have a very screwed up combo there. Like Blck92GT said You have an intake for 6500 Rpms with stock heads and a cam good good to 4700. You lossing 2000 RPMs of usable power.
Its not the heads holding you back from Rpm, its the cam. My friend has an 83 GT with stock heads, Edelbrock Torker II Intake and matching cam with a 2500-6500 RPM range and it pulls to 6200 RPM. Its definitly not the heads.
The cam has a power band to 4700, it should be able to rev higher. It doesn't mean the motor won't rev past that.
There is a problem elsewhere. Either spark or fuel. Could be bad timing or a bad ign module, plugged converters.
Omgitsa88Stang
10-05-2015 07:33 AM
