C-Clip eliminator kit
RE: C-Clip eliminator kit
ORIGINAL: PRO50SC
The axles are just pressed into them and then they are bolted on where the backing plates attach.
What's the advantage to them anyway? Anyone know? The only thing I can tell is them being pressed onto the axles and then bolted in is there is more surface area securing them in place over just a c-clip holding them in. maybe that's it.
The idea is that WHEN you break an axle inside the rear end, the c-clip eliminators will keep the axle from sliding out of the rear of the car, which will prevent you from crashing and wrecking the back end of your car
ORIGINAL: AdderMk2
Ive seen in track rules where they require them if you are running like 12's or something. I believe you only need them when you have lots of horsepower, which...most of us sadly do not yet
ORIGINAL: musclemustang94
ORIGINAL: primetime5.0
my buddy has c-clip eliminators in his 03 cobra, obviously with disc brakes
