car wont start
car wont start
so i go out to grab a bite to eat ....come bak to my car wont start ....car has everything brand new dist.,wires,blaster coil,spark plugs,alt,starter,fuel pump, cant figure it out ...haha the car seems to know whenever i have extra money to blow
RE: car wont start
make sure all your grounds are tight as well, and all the new stuff has not moved and maybe you forgot to tighten something, check every connection over just to make sure, including all hoses, electrical, anything, plus what Pro said.
RE: car wont start
well it does crank just wont start and the car has been running for a couple weeks now none of this stuff was installed in the past month it has been running fine the whole time...... i personallydont see anything physically wrong at the moment...............
RE: car wont start
just throwing this out there because it happend to me a couple nights ago.
for some reason my car was throwing a bunch of codes so i cleared them and tried to crank it, wouldnt start so i ran it again and the only code that came up before and again was "TPS failure".
had to go to autozone and buy a new tps for like $30 bucks. started right up.
save urself some money and scan the codes before dropping some cash on some parts u may not need.
RE: car wont start
ORIGINAL: 93 LX FiveO
Also try to routine, car wont start diagnostic, check grounds, battery voltage, starter connections, solenoid bypass, solenoid switches when ignition is turned, etc. Has your volt gauge been low lately? Any chance moisture in the distributor/plugs/wires? Try swapping battery with another vehicle quick and see if that helps.
Good Luck
RE: car wont start
ORIGINAL: phazeone
Read ALL of the replies and answer ALL of the questions. Ppl having to repeat themselves gets old!!!
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
