????Gas Shooting Out Of Carb!!!????
RE: ????Gas Shooting Out Of Carb!!!????
the fuel pump flows 5-8 psi. its an aftermarket POS electric pump. I took out the needle and it was a little sticky. i cleaned it up with some carb cleaner and tryed it again and it still dieseled but this time no fountian of fuel. what could be causing the dieseling?
Ive checked the timing.. it is set at about 23* with the vacume line off..If iretard it anymore than it is it starts to backfire when i hit the gas. if i advance it, it starts to idle really high and ive adjusted the fast idle screw all the way out and the idle wont go any lower..Im pretty sure i got the float levels right.
Even if its an aftermarket pump 5 lbs is still a bit too much, it should be at 2 to 3 lbs max or you just force too much in it, how do you know it is 5-8 psi? is that what the box said or do you actually have a gauge on the fuel line?
