New Explorer GT-40 intake question
OK, so I think this one is new, but after searching I couldn't find it. Does it matter when year intake you get. I know the gt-40 (Not the gt-40P) is the 96-97.5 heads. But what about the intake. If I get a gt-40p intake will it work with gt-40 heads????). And is there any way to determine what year or style the intake is if you don't know what year 5.0 it cam off of???
RE: New Explorer GT-40 intake question
there is no such thing as a gt40p intake. they are called gt40e and i thought that they went on both the 40 and the 40p's? i can't see how it would work if it sits an inch forward either.
i have done it twice, to find the year model check the casting #'s
the lower is just like the cobra/gt 40, its just the upper is a shorter intake closer in size to the ho, you will have to drill a hole in the intake to add what i think is called the air charge sensor, takes a 3/8 pipe tap to do so, it a good cheap intake with good bang for the buck, i just installed it on my 93 and the strut tower brace clears it just fine so i can't see it setting any different then just the stocker
think the casting# like x6 or x7 which would be a 96 or 97 , anyway that second # should tell the year model , can call ford to make sure if it makes any difference to you, one of mine call off a 99 and the other off a 96-7 and they are both the same
Luke9222
10-22-2015 11:55 PM
09-01-2015 08:16 PM
