Better brakes
Old 12-29-2006, 12:09 AM
PJB
PJB's Avatar
Default RE: Better brakes
From what I understand the wheel choices are limited with the Lincoln rotors.
Is there really a noticeable improvement with just the calipers though? Direct bolt on even though the Lincoln had bigger rotors?
PJB is offline
Old 12-29-2006, 12:12 AM
liketoskate1
liketoskate1's Avatar
if u put just the lincoln calipers on the stock rotor they are a direct bolt on i would think that there should be a noticable difference
ORIGINAL: PJB
liketoskate1 is offline
Old 12-29-2006, 01:25 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
the lincoln calipers are the same as the mustang a definite improvement they are a direct blot on they use the stock mustang rotor or u can go 5 lug lincoln and they bolt on directly
the wheel selection problem is that the bearing cap sticks out of mo9st aftermarket wheels nothing an adpater will not fix
rmodel65 is offline
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Better brakes
