Got some questions about some wheels
I know absolutely nothing about wheel backspacing and offset so here's my questions. Lets say that I'm looking at a set of wheels, 15x8's all around. Specs are below. Simple question though. If I run a 205/55/15 on the front and like a 255 or a 265/60/16 in the back will these wheels work or are they going to stick out or anything?
15x8
offset:-19.00mm
Backspacing(in): 3.750 in.
center bore: 2.95 in.
15x8
offset:-19.00mm
RE: Got some questions about some wheels
i am almost certain a 5.0 uses 5.5" BS but i could be wrong.
you can measure it by laying the wheel down, and measuring from the mounting surface on the back of the wheel (like in between the lug holes) to the iner face of the rim
ORIGINAL: 92hatchLX
Smaller back spacing mean that I can run a wider tire or anything?
So maybe 225's on the front? I guess what I really want to know is if I get these wheels and throw some tires on em, is it going to look normal? I don't wanna look likeone of those mexican truckswith my wheels sticking 1 foot out of the wheel wells.
ORIGINAL: 92hatchLX
https://mustangforums.com/albumphoto...668&page=1
ORIGINAL: 92hatchLX
15x8
offset:-19.00mm
15x8
offset:-19.00mm
The backspacing of a wheel will be determined by the width and the application. For example: Ponies are 16x7 and have a 4.75 or 5" BS (IIRC), but a 17x9 wheel will have a 5.70-5.75" BS w/ a 18-19mm offset.
The offset is about right on those wheels, but the BS is not nearly deep enough.....
BTW, go to tirerack.com to find out about everything (tire sizing, wheel sizing, BS, offset, etc.)
