What suspension is everyone running
#21
RE: What suspension is everyone running
To answer the original ?:
I'm not sure what springs I've got...I think stock, but they could be the FRPP B or C springs. The front seems pretty harsh on speedbumps, even going slow, so I wonder sometimes if they're the specific rate set (C?). I've also got Monroe SensaTrac shocks/struts and will have my UPR U/L control arms installed by next week.
EDIT: MM CC plates, too.
I want the H&R SuperSports (to go w/ the poly isolators I already bought) and Tokico HP's.....
#24
UPR k-member, UPR coil overs with QA1 adj. front struts, UPR chrome moly a-arms, full length sub-frame connectors, stock GT rear springs, tubular upper/lower CA's, Strange adj. rear shocks and UPR caster/camber plates (coming soon).
#25
ORIGINAL: 7upedition
yea, I just spent a month researching shocks and i came to the conslusion billstein or tokico are best... i went with tokico for cost savings.
#26
D&D Front Coil Over Kit
MM C/C Plates
Tokico Illumina Shocks and Struts
MM K Member Brace
UPR U/L Control Arms
Eibach Lowering Springs (in the back)
Energy Suspension isolaters
Eibach Front/Rear Sway Bars
MM Subframes
MM Strut Tower Brace
MM C/C Plates
MM K Member Brace
MM Subframes
#28
ORIGINAL: 88BlueGT
I plan on running a mix of MM and D&D.
D&D K Member
D&D A Arms
Strange 10 way Adjustable Struts
MM C/C Plates
MM Control Arms
MM Panhard Bar
MM Subframes
Strange 10 Way Adjustable Shocks
etc. etc. etc.
D&D K Member
D&D A Arms
MM C/C Plates
MM Control Arms
MM Panhard Bar
MM Subframes
etc. etc. etc.
#29
ORIGINAL: 92civy
how are those strange 10 ways? i am looking into them.
ORIGINAL: 88BlueGT
D&D K Member
D&D A Arms
MM C/C Plates
MM Control Arms
MM Panhard Bar
MM Subframes
etc. etc. etc.
D&D K Member
D&D A Arms
MM C/C Plates
MM Control Arms
MM Panhard Bar
MM Subframes
etc. etc. etc.
#30
Front:
Moroso Drag Springs
Lakewood 90/10s
Stock K member and Control Arms
Rear:
Moroso Trick Rears
Comp. Engineering 3 way adjustables set at 50/50
Granatelli Adjustable Uppers & Lowers
8.8 Rear with moser 31 splines and an Eaton Carrier
Moroso Drag Springs
Lakewood 90/10s
Rear:
Moroso Trick Rears
