converting to mass air?
I just bought a 1987 Mustang gt w/t-tops and I want to convert it to mass air before I do any other mods on it. I have been doing a search and would like to know what is a good one to buy and where is a good place to buy it from. Thanks for any help and I am looking forward to modifing the car over the next year.
RE: converting to mass air?
Heres what i did, i bought a mass air conversion harness(came in a ziplock bag)from Excessive Motorsports. about $60. went to autozone bought a computer for a 92 5.0. took my speed density computer in for a core (they look exactly the same) bought a mass air meter there. then i bought a cold air induction for a mass air car (one with the crome tubes). and it is as easy as that. worked great for me for 5 yrs. i have a x303 came with no problems at all. mine is an 88 gt
Since you have to buy a MAF/MAS anyway, spring for a 70mm MAF & MAS from a 94-95 Mustang. Either V8, or 6cyl as they are the same.
The MAF Transfer is nearly identical between these 2 meters.
This swap will work so long as you are still using the stock 19lb injectors.
good luck,
jason
good luck,
jason
ORIGINAL: Streetracer911
what the hell is all of this MAF and what do I have to do to install it? What does it do?
ORIGINAL: 15austin
You dont have to repin the computer or anything like that, its all plug in play? I will switch to mass air and build the engine like I want if I can change to mass air withouth cutting any wires.... somebody please tell me this was so, I thought you had to hack into the wires and repin the computer?
That is what I am trying to find out is if there is a whole kit you can buy to convert over to mass air that is easy to install. I am planning on doing some mods and from what I understand I need to have mass air for anything to make a difference.
ORIGINAL: vristang
what year is your Mustang. It may have been factory installed?
