Someone please explain the brake proportioning valve
I have a proportioning valve mounted on the right side firewall. My brakes are ok, but they dont stop the car like I think they should. The car hasa rear disc conversion, and I know the car used to be raced on a road course, it has also been to a driving school by one of the previous owners. So I am assuming it was used to set the brakes for a particular track. If I increase the pressure on the valve, will this give me more braking power? Or am I moving brake pressure from front to rear or vise versa? I dont really understand how they work other than they control pressure so the car will not skid under hard braking. Can anyone elaborate on this for me?
RE: Someone please explain the brake proportioning valve
Yes, That valve is used to adjust front and rear pressure. Your front brakes do the majority of the stopping due to the weight transfer when stopping. You can adjust to 50/50 or 60/40 ect...
Is that style proportioning valve a stock item or is it an aftermarket add on?
It's aftermarket, we didn't get abrake proportioning valve from the factory.
Did your rear disc conversion come with a new master cylinder by chance? Because you need more pressure in the lines to use disc brakes. Your proportiong valve changes the balance of the pressure fore and aft when the front dips or if their is a load in the back or something. You probably need a new master cylinder with a bigger bore.
Also if you dont have steel braded brake lines that will make a huuuuuuge difference! It will help with mushy pedal under hard braking and sensitivity of the brakes. A must if you track it at all!
ORIGINAL: 92hatchLX It's aftermarket, we didn't get abrake proportioning valve from the factory. -P. |
ORIGINAL: P Zero The proportioning valve will increase pressure to the rear to help slow the vehicle faster and more evenly. -P. |
So, then I understand the front needs more pressure for braking perfomance. This is true in many applications, such as motorcycles where 80% of the stopping power is in the front rotors. I know I dont have braided lines, but why go to the trouble of installing a rear dics conversion, installing the valve, and not upgrading the lines? I am going to find out what rotors and pads I have on the back this weekend, they need some work. I guess I am just looking for a way to make sure I have all the available stopping power I need, and I am not familiar with the proportioning valve like it is set up.
But with a bike, you get two levers. ONe for the front and one for the rear. Discs are always better. Less surface area being used in drum brakes, plus they get hot. Steel lines are a big plus. I have been wanting to get some. Along with some drilled & slotted rotors.
