codes for turbo coupe rearend
ive read that the turbo coupe rearend bolts into the stock fox, and they has the disk brakes. does anyone know the codes for the ratios for the turbo coupe?
and im puttin headers in soon that i got from santa, i know how to do it but is there anything that you can tell me to make them go in smoother. they are BBK shorties.
[align=left] [/align]
RE: codes for turbo coupe rearend
the auto cars have 3.73 8.8 rear with disc brakes its the same length as the 93 cobra rear the manual cars have a 3.55 8.8 rear the brakes are 10.5 inch with integral parking brakes
those axles will stick out and make your wheels rub the fender. just buy some brackets off northracecars.com and pull the caliper and rotors off any rear disc t bird or turbo coupe. they'll bolt up just fine. i've done it a few times, you just have to grind a little off the axle housing. you'll see where when you align the brackets.
140
4-Lug Rear Disk Brake Conversion (10.125" Rotor)
http://www.northracecars.com/catalog/brakes/brakes.htm
140
Matt's 95 Stang
10-05-2015 07:16 AM
