d THE CAMZILLA
d THE CAMZILLA
Has anybody used the camzilla from ford racing if so did you like it or not also what would be a good came with noticable power gains for a 1994gt with exhaust, 5 speed, ignition, and venom 400 performance module.
RE: d THE CAMZILLA
Which one is Camzilla? X cam? You'll need to check piston to valve clearance for starters. You will pretty much kill the performance of your car if it's mostly stock.
What are your mods?
Here is a list of things to do before a cam:
GEARS!!!
Larger MAF and TB
Heads
Intake
Full Exhaust--headers, H/X pipe, cat back
Wires, Coil
A cam is one of the last things to do unless your are swapping it in w/ new heads and intake......
What are your mods?
GEARS!!!
Larger MAF and TB
Heads
Intake
Wires, Coil
RE: d THE CAMZILLA
ive got a z cam, pulls hard from 2500 to 6500, then again ive got a h/c/i
dont think it would help you out much. doesnt like to idle when its cold, parking lots arent always fun(surges off the idle), and i would reccomend having a 5 speed. sounds good, makes good power. any more questions just ask
